StarTech.com 2-Port Serial PCIe Card
Quicklinx: HKKQWS00 Mfr#: 2S232422485-PC-CARD
Wired / Wireless: [N/A]
Protocol: [N/A]
Form Factor: Plug-in card
Compatibility: [N/A]
Type: [N/A]
£64.74 ex VAT
£77.68 inc VAT
Add serial communication support to a desktop computer or Small Form Factor (SFF) system, using this 2-Port Serial PCI Express Card. The two DB9 ports can be independently configured to support RS-232, RS-422, and 2/4-wire RS-485 standards, for communication with compliant serial peripheral devices.
  • Per-Port Serial Configuration
    This PCIe Serial Card is equipped with on-board DIP switches, enabling each DB9 serial port to operate in RS-232, RS-422, and/or RS-485 mode(s). The card features LED indicators per port, providing real-time monitoring of port activity.
  • Configurable External SATA Power
    The PCI Express Serial Adapter Card features three power modes that are configurable via on-board jumpers, including 12V (1.5A per port), 5V (1.5A per port), or no power (RI), over pin 9.
  • Legacy Connectivity
    This serial card enables the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-Port PCIe Serial Card is an ideal system upgrade for a wide range of applications (e.g., point-of-sale terminals, PLCs, factory control and automation, scientific sensors, medical equipment, scanners, and oscilloscopes).
StarTech.com 2-Port Serial PCIe Card, Dual-Port PCI Express to RS232/RS422/RS485 (DB9) Serial Card, Low-Profile Brackets Incl., 16C1050 UART, TAA-Compliant, Windows/Linux, TAA Compliant - Level-4 ESD Protection (2S232422485-PC-CARD) - serial adapter - PCIe - RS-232 x 2 - TAA Compliant
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 2.0
Ports
RS-232 x 2
10.2 cm 1.6 cm
Length
10.5 cm
57 g
RS-232, RS-422, RS-485
Data Transfer Rate
921.6 Kbps
16C550 UART, 16C450 UART, 16C950 UART
Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.13 or later
TAA Compliant
Serial adapter
PCI Express x1
PCIe 2.0
Ports
RS-232 x 2
Wired
Data Transfer Rate
921.6 Kbps
Status Indicators
Status, data
Software flow control, hardware flow control, 256-byte FIFO, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), 15KV ESD Protector (HBM)
2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
2 x low-profile brackets
1 x serial panel (internal) - 30 cm
RoHS
TAA Compliant
10.2 cm
1.6 cm
Length
10.5 cm
57 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
140 g
70 °C
20 - 80% RH
HKKQ StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.42
HKKQ StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
HKKQ StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
HKKQ StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
Protocol: [N/A]
Type: [N/A]
