StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length
Quicklinx: 6BF8WS00 Mfr#: PEX2PCIE4L
Type: None
Compatibility: Unix, Mac, PC
Interface: [N/A]
Hurry, only 2 left in stock!
£333.85 ex VAT
£400.62 inc VAT
Add two PCI and two PCI Express expansion card slots to your desktop computer. The PEX2PCIE4L PCI/PCI Express Expansion Chassis provides a quick and simple I/O expansion solution to almost any PCI Express (PCIe) enabled system. Adding PCI/PCIe cards to a server or workstation, or providing a platform to swap cards between a mobile and desktop setup is a cost-effective and time-saving solution for maximizing the I/O capabilities of your system.
The external expansion chassis adds two full-length (38cm) PCI slots (32-bit/33MHz), as well as two PCIe x1 (single-lane) slots to a host computer through a single PCI Express connection. Providing total bandwidth up to 250MBps from the PCIe x1 host controller card allows the computer to function as though the expansion chassis cards were connected directly to the motherboard.
  • Versatile expansion slots
    This enclosure features two PCI slots and two PCI Express x1 slots, allowing users to connect a variety of add-on cards to enhance system functionality.
  • Broad compatibility
    Designed to work with both Mac and Unix systems, this expansion enclosure provides flexibility for diverse computing environments.
  • Robust environmental tolerance
    Able to function efficiently between temperatures of 0°C and 55°C, this product is suitable for a range of operating conditions.
  • Strict compliance standards
    This product meets FCC and RoHS regulations, ensuring safe and environmentally friendly usage.
  • Dependable power supply
    Equipped with an internal power adapter, this system ensures consistent power delivery for reliable operation.
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length (PEX2PCIE4L) - system bus extender
System bus extender
38.2 cm x 13.7 cm x 14.3 cm
4 kg
Power adapter - internal AC 120/230 V
P/N: SVA12M5NA
System bus extender
38.2 cm
13.7 cm
14.3 cm
4 kg
Enclosure Colour
Expansion Slots
2 (total) / 2 (free) x PCI
Compatible Slots
2 x PCI Express x1
1 x DVI cable - external - 91 cm
FCC, RoHS
AC 120/230 V
55 °C
P/N: SVA12M5NA
6BF8 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £333.85
6BF8 StarTech.com PCI Express to 4 Slot PCI Expansion System In Stock £376.57
6BF8 StarTech.com DC Power Adapter - 12V, 5A In Stock £44.00
Type: None
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
Interface: [N/A]
