This PCIe x1 to PCIe x16 Slot Extension adapter provides enhanced compatibility between motherboards and a variety of PCI Express expansion cards, allowing you to install a PCIe card (x1 - x16) in an x1 slot.
The PCI Express x1 to x16 adapter accommodates low profile x2, x4, x8, x12 or x16 PCI Express cards, eliminating the cost and hassle of upgrading a PCIe card or replacing the motherboard for the sake of compatibility.
- StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter - PCIe x1 to x16 Adapter (PEX1TO162) - PCIe x1 to PCIe x16 slot adapter
- Product Type
- Product Material
- Steel
- 4.43 cm x 12.7 cm x 0.85 cm
- 12 g
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- Product Type
- Product Material
- Steel
- 4.43 cm
- 12.7 cm
- 0.85 cm
- 12 g
- Shipping Dimensions (WxDxH) / Weight
- 4.6 cm x 21.9 cm x 15.8 cm / 80 g
- Limited warranty: - lifetime
- Designed For
StarTech.com PCI Express to PCI Adapter Card | In Stock | £34.40 |
StarTech.com PCI to PCI Express Adapter Card | In Stock | £36.69 |
