StarTech.com PCI to PCI Express Adapter Card
Quicklinx: 6PG2WS00 Mfr#: PCI1PEX1
Type: Adapter Card
£36.69 ex VAT
£44.02 inc VAT
Install half-height/low profile x1 PCI Express interface cards in a standard PCI expansion slot. The PCI1PEX1 PCI to PCI Express Adapter card lets you use low profile PCIe expansion cards in a server/desktop motherboard PCI slot. The adapter connects through a 32-bit PCI slot to provide a low profile PCIe x1 slot in its place; a spare, full size bracket is included for installation in larger desktop or server expansion slots that can accommodate a full-sized card.
The PCI to PCI Express Adapter features an innovative bracket design that adapts and secures the low profile PCI Express card into the converted slot, ensuring a versatile and economical solution for extending the usability of older PCI motherboards or using low profile PCIe cards that do not have PCI equivalents.
StarTech.com PCI to PCI Express Adapter Card - PCIe x1 (5V) to PCI (5V & 3.3V) slot adapter - Low Profile - PCI1PEX1 - PCIe x1 to PCI slot adapter
6 cm x 13.5 cm x 2 cm
27 g
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
6 cm
13.5 cm
2 cm
27 g
FCC, RoHS
Limited warranty: - 2 years
85 °C
6PG2 StarTech.com PCI Express to PCI Adapter Card In Stock £36.26
6PG2 StarTech.com PCI to PCI Express Adapter Card In Stock £36.69
6PG2 StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter In Stock £20.27
Type: Adapter Card
