StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black
Quicklinx: 8TJ8WS00 Mfr#: ST4300MINU3B
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
  • Windows 8 (32/64 bits)
£19.33 ex VAT
£23.19 inc VAT
Add four external USB 3.0 ports to your notebook or Ultrabook with a slim, portable hub. The ST4300MINU3B Portable 4 Port SuperSpeed Mini USB 3.0 Hub (Black) lets you expand your USB connectivity by turning a single USB 3.0 port into four external USB 3.0 ports. The integrated cable design makes this mini USB hub the perfect accessory for your Mac / PC notebook or Ultrabook computer.
The 4 Port USB 3.0 hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age.
Ideal for home and business users who require portability, the external USB 3.0 hub is USB-powered and features a rugged, compact design with a built-in cable so no additional cables are needed to connect the hub to your system.
StarTech.com 4-Port USB 3.0 SuperSpeed Hub - Portable Mini Multiport USB Travel Dock - USB Extender Black for Business PC/Mac, laptops (ST4300MINU3B) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0
3.9 cm x 7.6 cm x 1.4 cm
38 g
Apple MacOS X 10.0 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
P/N: FCREADMICRO3, MSDREADU3CA, USB3S2ESATA3
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
Status Indicators
4 x USB 3.0 Type A , 1 x USB 3.0 Type A
1 x USB cable - 14.5 cm
FCC, RoHS
3.9 cm
7.6 cm
1.4 cm
38 g
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8TJ8 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
8TJ8 StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.33
8TJ8 StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.75
8TJ8 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
8TJ8 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
8TJ8 StarTech.com 4 Port Portable USB 3.0 Hub In Stock £24.39
8TJ8 StarTech.com 4 Port USB C Hub with PD 2.0 In Stock £34.96
8TJ8 StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £46.96
8TJ8 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £29.79
8TJ8 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.49
8TJ8 StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.36
8TJ8 StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £31.05
8TJ8 StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £42.16
8TJ8 StarTech.com 7 Port USB C Hub - C to C & A In Stock £66.79
8TJ8 StarTech.com 7 Port USB-C Hub - C to C & A In Stock £70.78
8TJ8 StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
8TJ8 StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.28
Type: USB Hub
Speed: 5Gbps
Ports: 4
