StarTech.com 4 Port USB 3.0 Hub A to C & A
Quicklinx: D4SXWS00 Mfr#: HB30A3A1CST
Type: USB Hub
Interface: USB, USB 3.1 Type C
Speed: 5Gbps
Ports: 4
Form Factor: External
Hurry, only 1 left in stock!
£41.13 ex VAT
£49.35 inc VAT
Add three USB Type-A ports and one USB Type-C port to your computer, using this mountable USB 3.0 (5Gbps) hub. This 4-port USB 3.0 hub turns your laptop or desktop USB-A port into two standard USB-A ports, one USB-A fast-charge port and one USB-C port. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 4-port hub is designed for easy port access, when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The USB-C port is ideal for connecting new USB-C devices, like an external USB-C drive, to a traditional USB-A port on your computer.
It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly.
This hub is perfect the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use.
With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or wall, to better suit your needs.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it is charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow.
  • Connect more devices quickly and easily
    The 4-port hub is designed for easy port access, when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports. With extra USB 3.2 Gen 1 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The USB-C port is ideal for connecting new USB-C devices, like an external USB-C drive, to a traditional USB-A port on your computer. It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly.
  • Enjoy mounted or desktop convenience
    This hub is perfect the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use. With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or wall, to better suit your needs.
  • Charge-and-sync your mobile devices
    With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it is charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow. The HB30A3A1CST is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com 4 Port USB 3.0 Hub, USB Type-A to 1x USB-C & 3x USB-A, Commercial Metal USB Hub, SuperSpeed 5Gbps USB 3.1/3.2 Gen 1, Self Powered, BC 1.2 Fast Charge/Sync, Mountable/Rugged - Windows/macOS/Linux (HB30A3A1CST) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB-C
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V
6 cm x 10 cm x 2.6 cm
200 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
P/N: SVA12M2NEUA, SVA12M5NA
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
Port status, power
3 x USB 3.0 Type A 2.4A charging port , 1 x USB 3.1 Gen 1 Type C , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
Rubber feet, mounting brackets, mounting screws
1 x USB-A to USB-B cable - 1 m
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
6 cm
10 cm
2.6 cm
200 g
5 °C
35 °C
20 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
D4SX StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £18.86
D4SX StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.25
D4SX StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.90
D4SX StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £29.84
D4SX StarTech.com 4 Port Portable USB 3.0 Hub In Stock £23.79
D4SX StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.31
D4SX StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £12.71
D4SX StarTech.com DC Power Adapter - 12V, 2A In Stock £11.71
D4SX StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
D4SX StarTech.com 1m USB A to C Cable - USB 3.0 In Stock £8.39
D4SX StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £41.13
D4SX StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £24.21
Type: USB Hub
Interface: USB
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 4
