StarTech.com 2m 6ft USB 3.0 C to B Cable
Quicklinx: CWB5WS00 Mfr#: USB315CB2M
Length: 2m
More than 50 In Stock
£12.71 ex VAT
£15.25 inc VAT
Connect USB 3.0 USB-B devices to your USB Type-C or Thunderbolt 3 computer. This USB-C to USB-B cable lets you connect your USB 3.0 peripheral devices, such as a printer, external drive or docking station to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
Note: USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
  • Efficient data transfer
    The USB C to USB B Printer Cable supports a data transfer rate of 5 Gbps, ensuring rapid communication between your devices.
  • Flexible length
    At 6 ft / 2 m in length, this cable provides ample reach for connecting devices without compromising on flexibility and positioning.
  • Broad compatibility
    Designed to meet USB 3.0 and USB 3.1 Gen 1 standards, this cable is compatible with a wide range of USB devices, facilitating seamless integration.
  • Durable design
    Constructed with high-quality materials, this cable is built to withstand daily use while providing reliable performance.
  • Versatile connectivity
    Featuring male USB-C and male USB Type-B connectors, the cable ensures a dependable connection for printers and other peripherals.
StarTech.com USB C to USB B Printer Cable - 6 ft / 2m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB315CB2M) - USB cable - 24 pin USB-C to USB Type B - 2 m
USB cable
5 Gbps data rate
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type B - male
USB 3.0/ USB 3.1 Gen 1
P/N: HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, HBS304A24A, MST30C2HDPPD, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
USB cable
5 Gbps data rate
Length
2 m
Connector
24 pin USB-C - male
CWB5 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
CWB5 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.00
CWB5 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £25.34
CWB5 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £46.54
CWB5 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £60.78
CWB5 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £108.12
CWB5 StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.60
CWB5 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £125.14
CWB5 StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £61.67
CWB5 StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.92
CWB5 StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £54.82
CWB5 StarTech.com 2m 6ft USB 2.0 C to B Cable In Stock £12.69
CWB5 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.13
CWB5 StarTech.com 3m USB 2.0 C to B Cable In Stock £15.57
CWB5 StarTech.com 0.5m USB 2.0 C to B Cable In Stock £8.41
CWB5 StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £30.29
CWB5 StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.26
Length: 2m
