StarTech.com 4 Port USB 3.0 Hub with USB C
Quicklinx: CVXSWS00 Mfr#: HB30A3A1CFB
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 4
Form Factor: External
£30.63 ex VAT
£36.75 inc VAT
Add four USB 3.0 (5Gbps) ports to your laptop, including three USB Type-A ports, and one USB Type-C port. Here's an easy way to connect a wider range of peripherals to your laptop. This 4-port USB 3.0 hub turns your laptop's USB-A port into three USB-A ports (5Gbps), and one USB-C port. The hub is USB powered, so you can connect devices virtually anywhere you work or go.
Now, you can use your laptop's traditional USB Type-A port to expand your connectivity, and connect your newer USB Type-C devices to your laptop.
This USB 3.0 hub lets you expand your USB connection options using the USB-A port on your computer. (USB 3.0 is also known as USB 3.1 Gen 1.) It offers three USB-A ports and one USB-C port, so you can connect traditional USB devices now, while still being able to connect USB Type-C devices in the future.
It's the ideal way to connect your new USB-C equipped device to your laptop's traditional USB-A port.
With a compact and lightweight design, the USB-powered hub is tailored for mobility. It easily tucks into your carrying case and expands your connectivity when traveling.
This versatile USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The 4-port USB 3.0 hub can help if you need a way to connect your newer USB-C peripherals to your existing laptop. Now you can access your USB-C device while avoiding the cost of purchasing a newer laptop that features a USB Type-C port.
The bus-powered hub installs quickly with no additional drivers or software required, and it's compatible with virtually all operating systems.
  • Versatile connectivity
    The StarTech.com 4 Port USB 3.0 Hub offers a blend of 1x USB-C and 3x USB-A ports, providing a versatile solution for connecting a wide range of devices. Whether it's for a laptop or desktop, this hub ensures compatibility across multiple platforms including Windows, macOS, and Linux.
  • High-speed data transfer
    Equipped with USB 3.0 ports, this hub supports data transfer rates of up to 5 Gbps. It's suitable for tasks such as transferring large files, streaming HD videos, or syncing data across devices.
  • Compact and portable
    Designed with portability in mind, the USB Bus Powered hub is lightweight and compact, making it an excellent choice for professionals on-the-go. Its form factor ensures it can be easily packed into a laptop bag without adding bulk.
StarTech.com 4 Port USB 3.0 Hub, USB Type-A Hub with 1x USB-C & 3x USB-A Ports (SuperSpeed 5Gbps), USB Bus Powered, USB 3.1/USB 3.2 Gen 1 Adapter Hub, Portable USB Hub for Laptop/Desktop - Windows/macOS/Linux (HB30A3A1CFB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 3.0, USB 3.1
4 cm x 7.5 cm x 1.3 cm
40 g
P/N: CFASTRWU3C, SDMSDRWU3AC
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
USB 3.0, USB 3.1
3 x USB 3.0 Type A , 1 x USB 3.0 Type C
4 cm
7.5 cm
1.3 cm
40 g
CVXS StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.88
CVXS StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £21.21
CVXS StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.99
CVXS StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.07
CVXS StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.96
CVXS StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.09
CVXS StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £10.11
CVXS StarTech.com 4 Port Portable USB 3.0 Hub In Stock £24.96
CVXS StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £30.63
CVXS StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £41.24
Type: USB Hub
Speed: 5Gbps
Ports: 4
