USB-C Hub USB 3.2 Gen 1 (SuperSpeed 5Gbps) Built-in Cable Manager OS Independent. This 4 Port USB-C Hub enables you to connect four SuperSpeed USB 3.2 Gen 1 (5 Gbps) peripherals to your USB-C laptop or computer, an ideal solution for adding USB ports to a device that has limited USB ports available. It features a wrap-around cable manager, allowing you to tuck away the built-in cable for easy portability.
Note: USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps).
Expands the Connectivity of Your Computer
With this USB-C hub you can connect three USB-A devices, and one USB-C device, to a single USB-C port on your USB-C host device. The USB Type-C hub shares up to 15W (5V/3A) of power between connected devices, making it an ideal solution for connecting SSD/thumb drives, data storage, keyboards, mice, web cams and USB headsets. The USB hub is backward compatible with USB 2.0 (480 Mbps).
Highly Portable and Sleek
Featuring a durable plastic housing that's lightweight, and a sleek warp-around cable management system, this USB hub is the perfect travel companion for your laptop. Its small footprint ensures it will store easily in your laptop bag, and the wrap-around cable manager prevents tangles, ensuring easy accessibility. The USB hub is bus powered so there's no bulky external power adapter.
Wide Device Compatibility
The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux, iPadOS, Chrome OS and Android. The built-in host cable is 11 in. (28 cm) long, providing enough length to easily integrate into any workstation, reaching your host device even when it's placed on a laptop riser or stand. The USB-C host connection works with any USB-C or Thunderbolt 3 laptop, tablet, smartphone or 2-in-1, such as Surface Pro 7, Surface Book, iPad Pro, MacBook/MacBook Pro/MacBook Air, XPS or X1 Carbon.
HB30CM3A1CB is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
Expands the connectivity of your computer
With this USB-C hub you can connect three USB-A devices, and one USB-C device, to a single USB-C port on your USB-C host device. The USB Type-C hub shares up to 15W (5V/3A) of power between connected devices, making it an ideal solution for connecting SSD/thumb drives, data storage, keyboards, mice, web cams and USB headsets. The USB hub is backward compatible with USB 2.0 (480 Mbps). -
Highly portable and sleek
Featuring a durable plastic housing that's lightweight, and a sleek warp-around cable management system, this USB hub is the perfect travel companion for your laptop. Its small footprint ensures it will store easily in your laptop bag, and the wrap-around cable manager prevents tangles, ensuring easy accessibility. The USB hub is bus powered so there's no bulky external power adapter. -
Wide device compatibility
- StarTech.com 4 Port USB C Hub - 3x USB-A/1xUSB-C - 5Gbps USB 3.0 Type-C Hub (3.2 Gen 1) - Bus Powered - 11.2" Cable w/ Cable Management (HB30CM3A1CB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 3 x USB 3.2 Gen 1 + 1 x USB-C 3.2 Gen 1
- USB powered, cable management
- USB 2.0, USB 3.0, USB 3.1 Gen 1, USB 3.2 Gen 1
- 5 cm x 13.5 cm x 2 cm
- 74 g
- Space grey
- System Requirements
- Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 3 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type C
- Space grey
- Cables Included
- 1 x USB-C cable - 28 cm
- OS Required
- 5 cm
- 13.5 cm
- 2 cm
- 74 g
- Limited warranty - 2 years
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.54 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.23 |
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £7.73 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.21 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £10.31 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £9.97 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.01 |
StarTech.com 1m USB C Cable - USB 3.0 | In Stock | £11.26 |
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £8.64 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £26.45 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £38.06 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £31.91 |
