StarTech.com 4 Port USB 3.0 Hub USB-C & Power
Quicklinx: C53QWS00 Mfr#: HB30C3A1CFS
Turn a USB Type-C port on your laptop into three USB Type-A charge-and-sync ports (5Gbps) and one USB Type-C port. Here's an easy way to connect a wider range of peripherals to your USB-C enabled laptop. This 4-port USB 3.0 hub lets you connect both USB-C and USB-A peripherals to your laptop or desktop computer, through a single USB Type-C or Thunderbolt 3 port.
It's ideal for virtually any USB-C equipped laptop, such as your MacBook, Chromebook, Dell Latitude 11 5000 2-in-1, or Dell XPS 12.
This USB 3.0 hub lets you expand your USB connection options using the USB-C port on your computer. (USB 3.0 is also known as USB 3.1 Gen 1.) It offers one USB-C port and three USB-A ports, so you can connect traditional USB devices now, while still being able to connect the growing number of USB Type-C devices in the future.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
With three fast-charge ports, this hub can help to ensure that your tablets and smartphones are charged and ready to use when you need them. Each USB-A port supports USB Battery Charging Specification 1.2, so you can charge and sync up to three devices simultaneously. (The charge provided depends on the number of devices connected and the amount of power current each device draws. The hub's USB-C port does not support charging.)
This self-powered USB 3.0 hub comes with an external power adapter to support power-hungry USB devices, such as larger external hard drives and enclosures, which require more power than USB power can provide on its own. Plus, the versatile USB 3.0 hub takes up minimal space on a desk, so it fits perfectly in hot-desk or BYOD environments.
With its compact and lightweight design, the USB hub is also ideal for mobile use. You can simply tuck the hub and power adapter into your laptop bag to expand your connectivity when you're traveling.
Avoid the cost of purchasing new peripherals, by using this USB 3.0 hub with your current USB 3.0 and 2.0 devices. The self-powered hub installs quickly with no additional drivers or software required, and it's compatible with virtually all operating systems.
Startech USB C Hub - 4 Port USB-C to USB-A (3x) and USB-C (1x) - with Power Adapter - USB Type C Hub - Port Expander (HB30C3A1CFS) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB 3.1
USB 1.1, USB 2.0, USB 3.0, USB 3.1
AC 120/230 V / DC 5 V 1 A
4 cm x 7.5 cm x 1.3 cm
33 g
Australia, North America, United Kingdom, Europe
P/N: 2SD4FCRU3C, CFASTRWU3C, FCREADU3C, MSDREADU3CA, MST30C2DPPD, S251BU31C3CB, SDMSDRWU3AC, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Genesys Logic GL3522
3 x USB 3.0 Type A , 1 x USB 3.1 Type A
External power adapter
Electric Current Required
1 A
1 x USB-C cable - 11.4 cm
Plug and Play, FCC, RoHS, WEEE, RCM
4 cm
7.5 cm
1.3 cm
33 g
60 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
C53Q StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.33
C53Q StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White In Stock £19.33
C53Q StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.75
C53Q StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
C53Q StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
C53Q StarTech.com USB-C to Gigabit Adapter In Stock £26.04
C53Q StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
C53Q StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
C53Q StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
C53Q StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £29.79
C53Q StarTech.com 7 Port USB-C Hub - C to C & A In Stock £70.78
C53Q StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
C53Q StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
C53Q StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.28
