StarTech.com Dell EMC QSFP-40G-LR4 Comp QSFP+ SM Module
Quicklinx: FHK9WS00 Mfr#: QSFP40GLR4ES
The QSFP40GLR4ES is a Dell EMC QSFP-40G-LR4 compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-LR4 compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC QSFP-40G-LR4 Compatible QSFP+ Module, 40GBASE-LR4, 40GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+, LC Connector, 10km, 1311nm, DDM - Lifetime Warranty (QSFP40GLR4ES) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO single-mode
Plug-in module
Cabling Type
40GBase-LR4
Data Transfer Rate
40 Gbps
Optical Wave Length
1311 nm
40GbE
Max Transfer Distance
10 km
5.84 cm x 1.39 cm x 1.26 cm
40 g
Plug-in module
Wired
Cabling Type
40GBase-LR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
1311 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBase-LR4 - MPO single-mode female
MTBF
8,596,956 hours hours
UL, FCC, RoHS, REACH, MSA
1.3 Watt
5.84 cm
1.39 cm
1.26 cm
40 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
35 cm
Shipping Weight
40 g
Limited warranty - lifetime
