StarTech.com Juniper SFP-1GE-T Compatible SFP Copper Module - 1000Base-T
Quicklinx: FJNRWS00 Mfr#: SFP1GETST
Type: Modules
36 In Stock
£28.88 ex VAT
£34.65 inc VAT
The SFP1GETST is a Juniper SFP-1GE-T compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-1GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 (Copper) Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFP1GETST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
Juniper EX-SFP-1GE-T
1.37 cm x 6.8 cm x 1.4 cm
24 g
Plug-in module
Silver
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
100 m
Auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female
MTBF
4,655,371 hours
FCC, RoHS, REACH, MSA
1.3 Watt
1.37 cm
6.8 cm
1.4 cm
24 g
Shipping Width
9.4 cm
Shipping Depth
11.9 cm
Shipping Height
3.2 cm
Shipping Weight
51 g
Limited warranty - lifetime
Type: Modules
