The Sanus VuePoint F35c is a tilting TV wall mount for most 32" - 47" flat-panel TVs up to 80 lbs. The great technology allows -10°/+5° of tilt with the touch of a finger, making it easy to reduce glare and improve viewing angles without the use of tools. Its low-profile design places the TV just 2" from the wall for a clean, flush appearance. Brackets easily shift left and right on the wall plate to allow perfect TV placement, even with off-center wall studs.
- Sanus VuePoint F35C-B2 mounting kit - for flat panel
- Product Type
- Mounting kit
- Mounting Components
- Tilt wall mount
- Tilt
- 15°
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-47"
- VESA Mounting Interface
- Up to 400 x 400 mm
- Max Load Weight
- 36 kg
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- 32"-47"
- Tilt
- 15°
- Max Load Weight
- 36 kg
