The Sanus SimplySafe mount is a low-profile wall mount solution for most 22" - 50" flat-panel TVs up to 80 lbs. Its low-profile design places the TV just 1.1" from the wall, so it hangs like a work of art. Angled slots and an integrated level make leveling and installation quick and easy. A safety latch secures your TV to the wall for added safety.
- Sanus SimplySafe VML41 mounting kit - for TV - black
- Product Type
- Mounting kit
- Mounting Components
- Fixed wall mount
- 45.09 cm x 7.04 cm x 2.84 cm
- Tilt
- 5°
- Adjustments
- Tilt
- 1.77 kg
- Recommended Use
- TV
- Recommended Display Size
- 22"-50"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 100 x 200 mm, 200 x 300 mm, 300 x 400 mm
- Max Load Weight
- 36.29 kg
- Black
- 10 years warranty
- 45.09 cm
- 7.04 cm
- 2.84 cm
- 1.77 kg
- Black
AV Furniture
- Mounting kit
- Fixed wall mount
- Recommended Use
- TV
- 22"-50"
- Tilt
- 5°
- Adjustments
- Tilt
- Max Load Weight
- 36.29 kg
- Limited warranty - 10 years
