Sanus VuePoint Low-Profile Wall Mount - 32"-47" TVs
Quicklinx: FW2KWS00 Mfr#: F32C-B2
Type: Mounting kit
40 In Stock
£24.99 ex VAT
£29.98 inc VAT
The Sanus VuePoint F32b is an unparalleled wall mount solution for most 32"-47" flat-panel TVs up to 80 lbs. Its low-profile design sits just 0.9" from the wall for a flush appearance that makes it great for ultra-thin TVs. Its lateral shift feature allows the brackets to move left and right on the wall plate for perfect TV placement, even with off-center wall studs. A latching mechanism holds TV securely on the wall.
Sanus VuePoint F32b mounting kit - Low Profile Mount - for TV
Mounting kit (Low Profile Mount) - wall-mountable
Mounting Components
Wall mount
39.37 cm x 2.29 cm x 43.03 cm
Recommended Use
TV
Recommended Display Size
32"-47"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 200 x 100 mm
Max Load Weight
36.36 kg
5-year warranty
39.37 cm
2.29 cm
43.03 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Design
Low Profile Mount
Recommended Use
TV
Placing / Mounting
Wall-mountable
32"-47"
Max Load Weight
36.36 kg
Lateral shift
Limited warranty - 5 years
Type: Mounting kit
Brand: Sanus
