The VuePoint FPA405 soundbar mount attaches directly to wall mounts and positions the soundbar below mounted TVs. It supports up to 15 lbs, and is easy to assemble.
- Sanus VuePoint mounting kit - for sound bar
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- 2 mounting brackets
- Recommended Use
- Sound bar
- Max Load Weight
- 6.8 kg
AV Furniture
- Mounting kit
- Recommended Use
- Sound bar
- Placing / Mounting
- Wall-mountable
- Max Load Weight
- 6.8 kg
