Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
- Philips Hue White ambiance - LED light bulb - shape: A60 - E27 - 8.5 W - warm to cool white light - 2200-6500 K (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8.5 W
- Wattage Equivalent
- 60 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 806 lumens
- Dimmable
- Intelligent Assistant
- Siri, Cortana, Google Assistant, Alexa - indirect
- Platform
- Hue
- Communications Technology
- Bluetooth
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8.5 W
- 60 W
- A+
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 806 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light, Android compatible, iOS compatible, remote controlled
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Bluetooth
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 110 mm
- 72 g
- -20 °C
- 45 °C
