Philips Hue Lucca Wall Lantern
Quicklinx: GVYZWS00 Mfr#: 915005561201
Type: Wall lamp
Compatible With: Alexa, Google Assistant
Hurry, only 3 left in stock!
£58.33 ex VAT
£69.99 inc VAT
Now expand Hue to your outdoors. The Lucca wall lantern can be connected to your existing Hue bridge to get all the features, like away-from-home control, geofencing and scheduling. Hue bridge not included.
Set your lights to welcome you home
Experience the comfort of your lights turning on automatically when you arrive and turning off when you leave. Unpack your car, enter your house, all with the comfort of the right light. Just set the Hue app to Home or Away mode to switch on all your lights, or let geolocation do it for you, all without touching a button. It's as easy as that.
Smart control, home and away
Light up your outdoor spaces and see what's going on outside. By connecting your outdoor lights with the Hue Bridge, you can control them in any way you like. With our indoor remote-control options such as the Philips Hue app or using your voice (Amazon Alexa, Apple HomeKit or Google Assistant), you can control your outdoor lights. You can set light schedules to mimic your presence. Control your outdoor lighting from the comfort of your home or from any other location.
Set timers for your convenience
Enjoy longer evenings outside, finish the gardening or just take the rubbish out after sunset. Have your Philips Hue lights turn on automatically by setting schedules or using the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on.
Installation-free dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. To dim the lights, you don't need any wiring, an electrician or installation.
Control it your way
Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
Requires a Philips Hue bridge
Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
High-quality aluminium and superior synthetics
The products are made specifically for outdoor use. We use the highest-quality materials to ensure the best performance in outdoor conditions, as well as smart use of materials to optimise radio frequency.
  • Smart control, home and away
    Light up your outdoors and see what's going on outside. By connecting your outdoor lights with the Hue Bridge you can control them in any way you like. Use the Philips Hue indoor switches or the Philips Hue app on your device. You can even use your voice (Amazon Alexa, Apple HomeKit or Google Assistant) to control your outdoor lights. Set light schedules to mimic your presence. Control your outdoor lighting from the comfort of your home or from any other location.
  • Set timers for convenience
    Enjoy longer evenings outside, finish yard work or just bring the garbage outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never again have to worry whether you've left any lights on.
  • Installation free dimming
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is most common and ideal for general outdoor use.
Philips Hue White Lucca - wall lamp - LED light bulb - E27 - 9.5 W - warm white light - lantern - antracite
Wall lamp - lantern
Light Source Type
LED light bulb
Supported Light Bulbs Qty
1
Dimmer
Antracite
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Luminous Power
806 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Wall lamp
Shape
Lantern
1
Compatible Light Bulb Energy Class
A, B, C, D, E, A++, A+
Dimmer
Waterproof
Double insulated, weatherproof, outdoor usage, splashproof, remote controlled, auto power on/off, day/night adjustable sensor
Light Source
LED light bulb
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
A+
Warm white light
Luminous Power
806 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Product Material
Aluminium, synthetics
Body Colour
Antracite
IP44
170 mm
215 mm
115 mm
1.065 kg
190 mm x 235 mm x 140 mm / 1.275 kg
Type: Wall lamp
Brand: Philips
