Philips Hue Lightstrip Plus V4 1m Extension
Quicklinx: FVSNWS00 Mfr#: 929002269201
Type: Light strip extension
Compatible With: Siri, Google Assistant
Select:
  • Extension
Hurry, only 1 left in stock!
£20.83 ex VAT
£24.99 inc VAT
This extension is compatible with V4 Base only.
Extendible up to 10 metres
Extend your Philips Hue Lightstrip Plus by up to 10 metres by adding 1-metre extensions to cover larger surfaces and enable wider applications. From bright cove lighting to ambient navigation light in your hallway or stairs, anything is possible. Philips Hue lightstrip plus gives you full colour consistency from the first to the last extension.
Create the cosiest spot
Place a lightstrip where you like to relax most. Dim it down low, set to warm colours, and make your space comfortable, cosy, and completely your own.
Get the perfect atmosphere
From fancy get-togethers to family game nights, whatever occasion can be dressed up with the right colourful light.
Complement decor with light
Lightstrips can be tucked behind cabinets or underneath shelves to give any space an interesting, colourful, and ever-changing design element.
Control your way
Use the Hue app, your voice, or smart accessories to control your setup.
Customise with the Hue app
Set up and customise right in the Hue app! Easily change the colour, create automations, and more to make your lightstrip work for your space and the occasion.
Add accessories
Get a little more convenience out of your lightstrip with easy-to-use accessories such as a dimmer switch or motion sensor.
Go hands-free with voice
Pair with smart home assistants such as Amazon Alexa, Apple Home, and Google Assistant, to control your lightstrip with your voice.
Bright, powerful light
Get consistent colour — and with millions of them, it's really any colour — and bright, beautiful light.
Optimal design, optimal effect
The transparent sleeve was designed to keep dust and damage away from your lightstrip, meaning the light output is always at the optimal level.
Ultimate flexibility
Cut the lightstrip on the marked lines to fit your space, or make it even longer with extension strips up to 10 m. Bend, curve, and shape it to fit your space.
  • Flexible for every space, every moment
    Place a lightstrip where you like to relax most. Dim it down low, set to warm colors, and make your space comfortable, cozy, and completely your own. From fancy get-togethers to family game nights, whatever occasion can be dressed up with the right colorful light. Lightstrips can be tucked behind cabinets or underneath shelves to give any space an interesting, colorful, and ever-changing design element.
  • Control your way
  • Bright, powerful light
    Get consistent color - and with millions of them, it's really any color - and bright, beautiful light.
  • Optimal design, optimal effect
  • Ultimate flexibility
    Cut the lightstrip on the marked lines to fit your space or make it even longer with extension strips. Bend, curve, and shape it to fit your space.
Philips Hue Lightstrip Plus - light strip extension - LED - 11.5 W - 16 million colours - 2000-6500 K - multicolour
Light Source Type
LED
Multicolour
Wattage
11.5 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1600 lumens
Dimmable
Intelligent Assistant
Siri, Google Assistant - indirect
Platform
Hue
Communications Technology
Bluetooth
Extendable, ZigBee Light Link, 16 million changeable colours, cuttable
Light Source
LED
Built-in LED Lamp
Wattage
11.5 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1600 lumens
Starting Time
0 sec
Dimmable
Lifetime
25000 hours
Colour changing LED, instant full light
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth
Voice Controlled
Indirect
Product Material
Synthetics
Body Colour
Multicolour
Corner connector
IP20
Warranty
2 years
Length
1 m
62 g
88 mm x 55 mm x 140 mm / 115 g
-20 °C
45 °C
Brand: Philips
