Philips Hue Colour Bulbs 9W A60 E27 2-Pack
Quicklinx: H1RWBTBS Mfr#: 929002468819
Type: Light bulb
Compatible With: Alexa, Google Assistant
£67.21 ex VAT
£80.65 inc VAT
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Control lights with your voice
    Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - E27 - 9 W - 16 million colours/warm to cool white light - 2000-6500 K - white (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
White
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Nest, Echo
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
9 kWh
Power Factor
0.8
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Warm-Up Time
0.5 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
ZigBee technology, instant full light, Android compatible, iOS compatible, indoor usage, voice control, app-controlled, 16 million changeable colours, controlled via Bluetooth, preset modes
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Package
Hanging box
Warranty
2 years
6 cm
6 cm
11 cm
Diameter
60 mm
Length
110 mm
144 g
14 cm x 7 cm x 16.5 cm / 224 g
-10 °C
45 °C
Type: Light bulb
Brand: Philips
