Philips Enrave Hue pendant white
Quicklinx: GVBMWS00 Mfr#: 915005998001
The modern lineup of Philips Hue ceiling lights bring millions of colors to your living room or bedroom. The Philips Hue Enrave ceiling light offers warm-to-cool white light for the living room, bedroom or kitchen.
  • Set up hands-free voice control
    Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands.
  • Set the right mood with warm-to-cool white light
    Choose from over 50,000 shades of warm-to-cool white light to create the perfect ambiance in your home for each activity and time of day. Use bright, white light each morning to start the day energized and alert, or match your evening wind-down routine with a dim golden glow.
  • Optimized light recipes for your daily activities
    Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light.
  • Control lights instantly
    Get instant control over your Philips Hue smart lights with the Hue dimmer switch. With the touch of a button, your entire household can instantly dim or brighten the room, turn lights on and off, or set light scenes.
Philips Hue White ambiance Enrave - pendant lamp - LED - 33.5 W - warm to cool white light - 2200-6500 K - white
Pendant lamp
Recommended For
Kitchen, living room, bedroom, dining room
Light Source Type
LED
Style
Modern
Light Cover Type
Diffuser
Dimmer
White
Wattage
33.5 W
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
4300 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Communications Technology
Bluetooth
Frequency Required
50 - 60 Hz
Pendant lamp
Recommended For
Style
Modern
Light Cover Type
Diffuser
Dimmer
Protection class I, remote controlled, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
33.5 W
Colour Temperature
2200-6500 K
Luminous Power
4300 lumens
Lifetime
25000 hours
Power Requirements
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Compatible Application
Philips Hue App
Bluetooth
Voice Controlled
Indirect
Product Material
Metal, synthetics
Body Colour
White
Dimmer switch
IP20
Warranty
2 years
42.5 cm
42.5 cm
Min: 30 cm - max: 160 cm
4.14 kg
47 cm x 47 cm x 20.9 cm / 5.044 kg
