Brighten up your day with this Philips Hue smart table lamp.
Forget faffing with switches – control it from wherever you’re sat using your smartphone or tablet. And with a whopping 16 million shades to choose from, it’s safe to say there’s colours for every occasion.
There’s no need to worry about changing that bulb every week either, as its massive 25,000-hour lifespan LED bulb will keep things shining on and on…and on.
Won’t be back ‘til late? No worries. Just schedule your light to switch on automatically when it suits you best. Plus, you can dim the lights to suit your mood too, whether that’s nice and vibrant or something a bit more subtle. Watt a great idea.
Please note, to get the most out of this light’s features, like controlling it away from home and setting up routines, you’ll need a Philips Bridge (sold separately) and the free Philips Hue app. For everything else, you can control it with the free Philips Hue Bluetooth app. Both apps are compatible with all iOS and Android devices.
- Smart table lamp – control from your phone or tablet
 - White and coloured bulb – choose from 16 million shades
 - LED light with 25,000 hour lifespan
 - Schedule a timer to turn lights on automatically
 - Dim the brightness to match your mood
Carry light anywhere
Bring the Go portable table lamp where you need light most, such as inside to read or outside to illuminate a dinner party. -
Control your way
Use the on-product control button, the Hue app, your voice or smart accessories to control your lamp. -
Dynamic lighting effects
Use the on-product button to cycle through special light effects, such as a candlelight glow with Cozy candle. -
Smart battery management
Press and hold the button to put it in standby mode, saving battery life. If the lamp is off its charging base for longer than 12 hours, it'll go into battery save mode - wake it up by long pressing the button again.
 - Philips Hue Go - table lamp - LED - hue white and colour ambiance - black, dark grey handle
- Product Type
 - Table lamp
- Light Source Type
 - LED
- Dimmer
 - Black, dark grey handle
- Energy Efficiency Class
 - G
- Colour of Illumination
 - Hue white and colour ambiance
- Luminous Power
 - 530 lumens
- Communications Technology
 - Bluetooth, Zigbee
- Voltage Required
 - AC 220 - 240 V
- Product Type
 - Table lamp
- Dimmer
- Waterproof
 - Indoor/outdoor usage, portable, on/off switch
Light Source
 - LED
- Built-in LED Lamp
 - G
- Colour Rendering Index
 - 80
- Luminous Power
 - 530 lumens
- Lifetime
 - 20000 hours
Power Requirements
- Voltage Required
 - AC 220 - 240 V
 - Rechargeable
- Run Time
 - 48 hrs
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
 - Philips Hue Bridge
 - Bluetooth, Zigbee
- Product Material
 - Metal, silicone handle
- Body Colour
- Included Accessories
 - Charging base
- Package
 - Box
 - IP54, IP20
- Warranty
 - 2 years / 30 days return
 - 14.2 cm
 - 14.2 cm
 - 35 cm
 - 1.2777 kg
- Shipping Dimensions (WxDxH) / Weight
 - 20.9 cm x 21.9 cm x 38.8 cm / 1.821 kg
