Philips Hue Go and Dimmer Switch V2
Quicklinx: H4XHWS00 Mfr#: 919313000061
Type: Table lamp
Compatible With: Alexa, Google Assistant
£83.33 ex VAT
£99.99 inc VAT
Take smart light with you with the portable Hue Go. From a splash of colour to a mood-setting centrepiece, the Hue Go lets you set the perfect ambience. Works as a stand-alone light or as part of your smart lighting system with the Hue Bridge.
Dim or brighten the room, toggle light scenes or get the best light based on the time of day. The Hue dimmer switch attaches to walls or magnetic surfaces, but can also be used as a remote control anywhere in your home.
  • A truly portable smart light
    The Hue Go portable accent light can truly go wherever you want, thanks to its built-in, rechargeable battery. Bring this lamp along with you when you're traveling, use it as the centerpiece of a romantic dinner, or take it outdoors to enhance the atmosphere of your summer parties.
  • On-product control
    Change your light settings directly with the button on the light itself. Cycle through special light scenes, such as Sunday coffee and Enchanted Forest, by pressing the button. Press twice and hold on the second press to cycle through colors.
  • Dynamic, natural lighting effects
    Amp up the ambience of special moments with living light. Use dynamic light effects, such as Cozy Candle, Sunday Coffee, Meditation, Enchanted Forest and Night Adventure to create the perfect mood in any situation.
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theatre, enhance your home decor with color accents, and much more.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Sync films, TV programs, music, and games to smart lights
    Bring your entertainment to new heights by syncing the action on the screen or the beat of your music to your smart lights.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
Philips Hue White and Color Ambiance Go - table lamp - LED - 6 W - 16 million colours/warm to cool white light - 2000-6500 K - white
Table lamp
Recommended For
Living room, bedroom
Light Source Type
LED
Style
Modern
Dimmer
Usage Modes
Cosy candle, sunday coffee, enchanted forest, meditation, night adventure
White
Wattage
6 W
Wattage Equivalent
43 W
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
530 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Table lamp
Recommended For
Style
Modern
Dimmer
Usage Modes
Protection class III, portable, built-in battery
Light Source
LED
Built-in LED Lamp
Wattage
6 W
Wattage Equivalent
43 W
Colour Temperature
2000-6500 K
Luminous Power
530 lumens
Lifetime
20000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Lithium Ion - rechargeable
Internet of Things (IoT)
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Dimmer switch
Package
Box
IP20
Warranty
2 years
15 cm
7.9 cm
Length
15 cm
625 g
Type: Table lamp
Brand: Philips
