Peerless-AV Tilt Wall Mount for 32-56" Flat Panel Screens
Quicklinx: CZKBWS00 Mfr#: TRT650/BK
Easily install large screens with this simple, intuitive mounting solution. Its simple hook-on installation combined with its toolless tilt angle adjustment enables LCD and Plasma flat panel screens to be installed and adjusted quickly. Cables are easily managed behind the screen with large access ports in the wall plate.
Peerless Tilting Wall Mount TRT650 - mounting kit - for flat panel - smooth matte black
Mounting kit - wall-mountable
Mounting Components
Wall mount
76 cm x 4 cm x 40.8 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-56"
VESA Mounting Interface
700 x 400 mm
Max Load Weight
70 kg
Smooth matte black
5-year warranty
76 cm
4 cm
40.8 cm
Smooth matte black
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
700 x 400 mm
Cable Management
Integrated cable management
32"-56"
Adjustments
Tilt
Max Load Weight
70 kg
Integrated spirit level
Limited warranty - 5 years
