Peerless-AV Twin Pole Universal Adaptor Large
Quicklinx: BY49WS00 Mfr#: MOD-UNL2
£88.15 ex VAT
£105.78 inc VAT
With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular Mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for projects as well as for upgrading existing installations. The MOD-UNV2 provides additional screen fitment to the MOD-FPMS2 and MOD-FPMD2 with an adjustable VESA pattern from 300 x 200 to 600 x 400.
  • Versatile mounting
    Designed to support a wide range of display sizes from 46"-90", this universal adapter ensures compatibility with a vast array of LCD displays, making it a perfect fit for various environments, from conference rooms to home theaters.
  • Comprehensive compatibility
    Featuring flat panel mount interfaces of 300 x 200 mm, 300 x 300 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm, and 600 x 400 mm, the Dual-Pole Large Universal Adaptor offers flexibility, accommodating most display models and sizes.
  • Robust design
    With a maximum load weight of 96 kg, this mounting component is engineered for durability and reliability, ensuring your display remains securely in place.
Peerless Modular Series Dual-Pole Large Universal Adaptor mounting component - for LCD display - black powder coat
Mounting component
Mounting Components
Universal adaptor
62.4 cm x 2.1 cm x 42 cm
Adjustments
Tilt
1.59 kg
Recommended Use
LCD display
Recommended Display Size
46"-90"
VESA Mounting Interface
400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight
96 kg
Black powder coat
5-year warranty
62.4 cm
2.1 cm
42 cm
1.59 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Universal adaptor
Recommended Use
LCD display
46"-90"
Adjustments
Tilt
Max Load Weight
96 kg
Limited warranty - 5 years
Brand: Peerless-AV
