The Straight Column Ceiling Mount offers a 33" straight column from the ceiling attachment point to the center of the flat panel screen. The Straight Column Ceiling mount is ideal for sports facilities, airports, lobbies or retail environments. It delivers 20° of adjustable tilt and 360° of swivel. This mount ships complete with 2.5' fixed length extension column and theft resistant security fasteners.
Versatile placement
Designed for ceiling-mountable placement, this Peerless Solid-Point Flat Panel Straight Column Mount offers a secure and elevated position for flat panels ranging from 32" to 90", ensuring an optimal viewing experience in various settings. -
Secure installation
Equipped with Penta-pin security screws and a comprehensive mounting kit, including an adapter plate, ceiling arm box, ceiling plate, retaining collar, support pipe, and tilt bracket, this mount provides a robust and secure installation for your valuable display. -
Adjustable viewing
Featuring tilt adjustments, this mounting kit allows for the perfect viewing angle, enhancing the viewing experience by accommodating different viewer positions and reducing glare.
- Peerless Solid-Point Flat Panel Straight Column Mount PLCM-UNL-CP mounting kit - for flat panel - black
- Product Type
- Mounting kit - ceiling mountable
- Mounting Components
- Ceiling plate, tilt bracket, support pipe, adapter plate, ceiling arm box, retaining collar
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-90"
- Max Load Weight
- 90.7 kg
- Black
- 5-year warranty
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Ceiling mountable
- 32"-90"
- Adjustments
- Tilt
- Max Load Weight
- 90.7 kg
- Penta-pin security screws
- Limited warranty - 5 years
