Peerless-AV Pull-Out Pivot Wall Mount for 32" - 55" Displays
Quicklinx: CWDBWS00 Mfr#: HPF650
£195.41 ex VAT
£234.49 inc VAT
The HPF650 combines the best features of our FPS-1000 in one contemporary lightweight design, making it essential for on-wall or recessed/in-furniture application. With 30O of built in swivel, the HPF650 ensures your guests will always be able to find the perfect desired viewing angle. This mount is VESA® compliant, and accommodates virtually any flat panel display up to 60lb. Equipped with functionality, maximum aesthetics, versatile installation and endless display compatibility options, the HPF650 is the ideal solution for any hospitality or residential application.
Peerless SmartMount HPF650 mounting kit - Tilt & Swivel - for LCD display - black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, wall mount
44.9 cm 46.6 cm
Adjustable Depth
3.7-25.2 cm
Recommended Use
LCD display
Recommended Display Size
26"-47"
VESA Mounting Interface
100 x 100 mm, 400 x 400 mm
Max Load Weight
27 kg
44.9 cm
46.6 cm
Adjustable Depth
3.7-25.2 cm
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
26"-47"
Max Load Weight
27 kg
Brand: Peerless-AV
