Peerless-AV Full Service Thin Video Wall Mount with Quick Release
Quicklinx: 9Z0RWS00 Mfr#: DS-VW755S
28 In Stock
£302.14 ex VAT
£362.56 inc VAT
The DS-VW755S slim full service video wall mount with quick release offers an easy to install and service ADA compliant solution for both landscape and portrait displays. Designed for quick service access in recessed video wall applications, the DS-VW755S provides versatility demanded by today's integrator. With the quick-release functionality, users have the ability to articulate the display from the wall by gently pressing on the front of the display. Featuring tool-less micro adjustment at eight points, the mounts can overcome uneven walls to create a seamless video wall display. To aid in set up and service, the mount extends the display from the wall in a negative tilt position, providing convenient access to the bottom of the display. In addition, reusable custom wall plate spacers eliminating the guesswork and on-site installation calculations and measurement reducing installation time and cost. With no-tool-required micro-adjustments and easy display access for quick serviceability, it's a perfect video wall mounting solution.
  • Effortless installation
    The Peerless-AV SmartMount Full Service Video Wall Mount with Quick Release is designed for an effortless installation process, featuring adjustable depth and quick release mechanisms that simplify the setup and maintenance of video wall displays.
  • Versatile compatibility
    Accommodating a wide range of display sizes from 40" to 65", this mounting kit ensures a perfect fit for your video wall, supporting flat panel interfaces of 400 x 400 mm and a maximum load weight of 36.4 kg.
  • Integrated cable management
    With integrated cable management, the SmartMount keeps cables neatly organized and out of sight, maintaining a clean and professional appearance for your video wall installation.
Peerless-AV SmartMount Full Service Video Wall Mount with Quick Release DS-VW755S mounting kit - for video wall - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
50.8 cm 50.8 cm
Adjustable Depth
4.8-6.7 cm
Recommended Use
Video wall
Recommended Display Size
40"-65"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
36.4 kg
Black powder coat
5-year warranty
50.8 cm
50.8 cm
Adjustable Depth
4.8-6.7 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Video wall
Placing / Mounting
Wall-mountable
400 x 400 mm
Cable Management
40"-65"
Max Load Weight
36.4 kg
Adjustable depth, quick release
Limited warranty - 5 years
Brand: Peerless-AV
