Peerless-AV PRSS Projector Mount Ceiling Kit for Projectors up to 22kg
Quicklinx: 9Z1JWS00 Mfr#: MOD-PRSSKIT150
PRSS adjustable projector mount kit provides a trouble-free solution for quick and easy installations where variable drop length is needed. Simply mount to any common ceiling structure and utilize the height adjustable column along with the trouble-free set screw adjustment of the PRSS projector mount to quickly and easily align the projected image with the screen.
  • Effortless projector maintenance
    With its intuitively designed quick-release thumbscrew that smoothly unwinds to enable easy-glide removal of the projector in and out of the mount. No tools required.
Peerless PRSS PRSSKIT150 mounting kit - for projector - chrome, black powder coat
Mounting kit
Mounting Components
Ceiling plate, extension pole, spider adapter
Adjustable Width
11.8-44.8 cm
Adjustable Depth
22.5-44.8 cm
Adjustable Height
159.8-162.3 cm
Adjustments
Roll, pitch, yaw
4.3 kg
Recommended Use
Projector
Max Load Weight
22 kg
Chrome, black powder coat
5-year warranty
Adjustable Width
11.8-44.8 cm
Adjustable Depth
22.5-44.8 cm
Adjustable Height
159.8-162.3 cm
4.3 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Cable Management
Integrated cable management
Adjustments
Roll, pitch, yaw
Max Load Weight
22 kg
Limited warranty - 5 years
