Peerless-AV Paramount Articulating Wall Mount
Quicklinx: BTFRWS00 Mfr#: PA762
18 In Stock
£216.90 ex VAT
£260.28 inc VAT
The Paramount series wall mounts provide versatile and multi-functional features. With PA762, extend the display up to 21.32" (542mm) or fully-retract it to just 3.00" (76mm) from the wall for the perfect viewing angle. The Hook-and-Hang system offers easy, one-person installation of the display. A ratcheting handle provides locking tilt capability for quick adjustments to the amount of tilt, reducing glare and optimizing the viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
  • Versatile positioning
    With pan capabilities ranging from -45° to 45° and a tilt range of -5° to 15°, this mounting kit offers versatile positioning options for the optimal viewing experience.
  • Broad compatibility
    Designed to support flat panels ranging from 39" to 90" and capable of handling up to 68 kg, this mount is suitable for a wide array of display sizes, ensuring broad compatibility.
  • Streamlined setup
    Featuring integrated cable management and a comprehensive mounting component set, the installation process is streamlined, resulting in a clean and clutter-free setup.
Peerless-AV Paramount PA762 mounting kit - for flat panel - gloss black
Mounting kit - wall-mountable
Mounting Components
Articulating wall mount
Tilt
-5° to 15°
Pan
-45° to 45°
9.56 kg
Recommended Use
Flat panel
Recommended Display Size
39"-90"
VESA Mounting Interface
200 x 100 mm, up to 400 x 400 mm
Max Mounting Pattern Size
438 x 329 mm
Max Load Weight
68 kg
Gloss black
9.56 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
438 x 329 mm
Cable Management
39"-90"
Tilt
-5° to 15°
Pan
-45° to 45°
Max Load Weight
68 kg
Brand: Peerless-AV
