NetGear 24-Port Gigabit Ethernet Unmanaged Desktop / Rackmount Switch
SIMPLE PLUG-AND-PLAY DESIGN!
Quicklinx: BW22WS00 Mfr#: GS324-100EUS
The NETGEAR 24-Port Gigabit Ethernet Switch with simple plug-and-play, compact desktop design, and auto-sensing ports provides easy, reliable, and affordable connectivity for your home or small office network. A rugged metal enclosure, silent, fanless design, and both wall-mount and rack-mount kits allow for convenient deployment to build out your SOHO network. Auto-MDI/MDIX (eliminating the need for crossover cables), jumbo packet support, auto-negotiation for automatic connection at highest speeds, non-blocking switching architecture for maximum throughput, and energy-efficient technology for power savings (IEEE 802.3az and short cable power reduction) make the GS324 the perfect switch for the SOHO environment.
  • Robust performance
    With a bandwidth of 48 Gbps and forwarding performance capable of handling up to 1,448,000 packets per second, this switch ensures efficient data flow and high-speed connectivity for all connected devices.
  • Versatile connectivity
    Equipped with 24 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet, this switch offers ample ports for connecting multiple devices, making it ideal for expanding your network.
  • Energy-efficient design
    Features like ENERGY STAR Ethernet (EEE) and a fanless design not only reduce operational costs but also contribute to a quieter, more environmentally friendly workspace.
  • Easy installation
    The NETGEAR SOHO GS324 comes with a rack mounting kit, and its form factor allows for desktop, rack-mountable, or wall-mountable setups, offering flexibility in installation according to your space requirements.
  • Enhanced network management
    Quality of Service (QoS) support ensures critical data is prioritized, while auto-negotiation and auto-uplink adjust for the optimal link speed and routing, improving overall network efficiency.
NETGEAR SOHO GS324 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Bandwidth: 48 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 4.7 µs
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, 512KB packet buffer, EEE
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
25.2 cm x 18 cm x 4.4 cm
1.31 kg
3-year warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
24 x 1000Base-T RJ-45
Internal power supply
11.1 Watt
Power Consumption Stand by
8.47 Watt
Rack Mounting Kit
Included
Plug and Play
25.2 cm
18 cm
4.4 cm
1.31 kg
Limited warranty - 3 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
