Product
NetGear 5-port Gigabit Ethernet Switch
Quicklinx: B63JWS00 Mfr#: GS305-100UKS
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 in stock
£14.56 ex VAT
£17.47 inc VAT
Standard delivery Delivered within 3-5 working days
These NETGEAR home Ethernet switches provide an easy, reliable, and affordable way to expand your network connections in homes and small offices.
High-performance metal case provides easy, reliable and affordable Gigabit Ethernet connection for your home network. Features include auto-MDI/MDIX (eliminating the need for crossover cables) and LED indicators for ease of use. Energy-efficient technology provides power savings.
NETGEAR GS305 - Essentials Edition - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), metal housing
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
10.2 cm x 9.4 cm x 2.6 cm
240 g
United Kingdom
2 years warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
2K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
2.34 Watt
MTBF
3,670,229 hours
FCC Class B certified
United Kingdom
10.2 cm
9.4 cm
2.6 cm
240 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
Ports: 5
Managed: No
POE: No
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
