The NETGEAR ProSAFE Gigabit Smart Managed switches offer powerful Layer 3 Lite features with enhanced performance and usability. They are purposely designed for the future where increased traffic and application-oriented tasks demands more intelligence at the edge, higher reliability and improved network efficiency on top of operational cost savings and ease of management.
Comprehensive QoS features
Port-based or 802.1p-based prioritization. Layer 3-based (DSCP) prioritization. Port-based ingress and egress rate limiting. Advanced controls for optimized network performance and better delivery of mission-critical traffic such as voice and video. -
DHCP Snooping
Ensure IP address allocation integrity by allowing only clients with specific IP/MAC addresses to have access to the network. -
Dual firmware images and configuration files
Dual firmware image and dual configuration file for transparent firmware updates/configuration changes with minimum service interruption. -
Protected ports
Ensure no exchange of unicast, broadcast, or multicast traffic between the protected ports on the switch, therefore, improve the security of your converged network where your sensitive phone conversation can stay private and your surveillance video clips can be forwarded to their designated storage device without leakage or alteration. -
Dynamic ARP inspection
Prevents a class of man-in-the-middle attacks, where an unfriendly station intercepts traffic for other stations by poisoning the ARP caches of its unsuspecting neighbors. -
Multicast VLAN registration
Eliminates the replication of the same multicast traffic for every VLAN by sending multicast traffic only on to the dedicated multicast/source VLAN, resulting in more efficient utilization of network bandwidth.
- NETGEAR Smart GS748T - V5 - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L3 Lite - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 2 x Gigabit SFP + 2 x combo Gigabit SFP
- Performance
- Bandwidth: 100 Gbps
- Capacity
- Virtual interfaces (VLANs): 256 , ACL entries: 100 , Static routes: 32 , Layer 2 multicast groups: 512 , ARP entries: 512 , Priority queues per port: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
- Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, MLD snooping, DAI, LLDP support, DHCP client, Energy Efficient Ethernet, SPQ, static routing, 802.1x authentication, ToS, VoIP support, DSCP support, cable test, administrator's password, ARP inspection
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- 44 cm x 25.7 cm x 4.3 cm
- 3.46 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port transmission speed, link/activity
- 48 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 2 x 1000Base-X SFP uplink
- Power Device
- Internal power supply
- 41.4 Watt
- Rack Mounting Kit
- Included
- MTBF
- 390,728 hours
- cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 44 cm
- 25.7 cm
- 4.3 cm
- 3.46 kg
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.00 |
