These NETGEAR home Ethernet switches provide an easy, reliable, and affordable way to expand your network connections in homes and small offices.
Efficient connectivity
With five 1000Base-T RJ-45 ports, the NETGEAR GS305 switch facilitates high-speed wired connections, making it ideal for small office and home networks. Each port supports auto-negotiation, ensuring the best possible link speed and duplex mode, while auto-uplink adjusts for the different types of cables automatically. -
Energy saving
Incorporating Energy Efficient Ethernet (IEEE 802.3az) and a fanless design, this switch operates quietly and reduces power consumption, contributing to a lower cost of ownership and a more environmentally friendly office. -
Enhanced performance
The GS305 boasts a 10 Gbps bandwidth, allowing for seamless data transfer and handling high-demand network traffic. Combined with a 2K MAC address table and support for jumbo frames up to 9216 bytes, it ensures efficient network performance and management.
- NETGEAR GS305 - v3 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Bandwidth: 10 Gbps , Forwarding performance (64-byte packet size): 1448000 pps
- Capacity
- Packet buffer size: 128
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, Energy Efficient Ethernet, SOHO, WRR
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- 10.1 cm x 9.4 cm x 2.9 cm
- 250 g
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Capacity
- 2K entries
- 9216 bytes
- Status Indicators
- Power, link/activity
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 2.15 Watt
- Power Consumption Stand by
- 0.31 Watt
- MTBF
- 3,831,422 hours
- Plug and Play, IC Class B, VCCI, CB, FCC Part 15 B, LVD, RCM
- 10.1 cm
- 9.4 cm
- 2.9 cm
- 250 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
NETGEAR GS305 - V3 - switch - unmanaged - 5 x 10/100/1000
