NETGEAR M4300 16-port 10GBASE-T Copper Managed Switch APS600W
Quicklinx: FG2QWS00 Mfr#: XSM4316PB-100NES
Type: 10 Gigabit Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
£2,254.60 ex VAT
£2,705.52 inc VAT
The NETGEAR M4300-16X (XSM4316PB) ProSAFE Intelligent Edge 16-Port Fully Managed Stackable 10-Gigabit PoE+ Switch delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivalled ease of use. The M4300-16X can seamlessly stack with 1 Gigabit models within the series (sold separately), enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Layer 3 feature set includes static, dynamic and policy-based routing as standard. The NETGEAR M4300-16X is perfect for wireless access, unified communications and professional AV-over-IP installations.
  • Robust security
    With advanced encryption algorithms including 2048-bit RSA, 256-bit SHA-2, and 512-bit SHA-2, alongside RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, this switch ensures secure network access and data transmission.
  • High performance
    Equipped with a switching fabric bandwidth of 480 Gbps and a throughput of 238 Mpps, the NETGEAR M4300-16X delivers exceptional performance for high-speed data processing and transmission.
  • Versatile connectivity
    Featuring 16 ports supporting speeds up to 10GBase-T with PoE+ capability, this switch offers flexible connection options for a variety of devices while powering them over the Ethernet.
  • Comprehensive network features
    Supports a wide range of Layer 3 switching features including advanced routing protocols like OSPFv2/v3, PIM, and VRRP, ensuring efficient network traffic management and resilience.
  • Efficient management and operation
    Manageable via CLI, HTTP, HTTPS, and SNMP among others, with support for sFlow, dual firmware images, and front-to-rear airflow design for optimal performance and ease of management.
NETGEAR M4300-16X - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
16 x 100/1000/2.5G/5G/10GBase-T (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
500 W
Performance
Switching fabric bandwidth: 480 Gbps , Throughput: 238 Mpps
Packet buffer size: 16 MB
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
Remote Management Protocol
SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, NSF, sFlow, PVST+, UDLD, LLDP support, DHCP relay, LACP, RSPAN, PVRST, MIB, dual firmware images, CoS, PTP, STRG, AAA, UDP, PIM
IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V
21.2 cm x 34.5 cm x 4.4 cm
3.22 kg
United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE+
PoE Budget
500 W
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SHA, MD5, SSL 3.0, 2048-bit RSA, 256-bit SHA-2, 512-bit SHA-2, TLS 2.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
: 800 MHz
RAM
1 GB
Flash Memory
256 MB
Status Indicators
Status
16 x 100/1000/2.5G/5G/10GBase-T RJ-45 PoE+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
600 watt
AC 120/230 V
610 watt
80 PLUS Certification
80 PLUS
Front-to-rear airflow
MTBF
690,301 hours
SCCP
21.2 cm
34.5 cm
4.4 cm
3.22 kg
Limited warranty - lifetime
Ports: 16
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: £1500+
