NETGEAR Pro GS728TPPv2 24 port Smart Rack-Mountable Switch
Quicklinx: DWDRWS00 Mfr#: GS728TPP-200EUS
NETGEAR Smart Managed Pro Switches offer powerful L2 and L2+/Layer 3 Lite features, great PoE functionality, and enhanced performance and usability. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. These switches are optimized for network efficiency, operational cost savings, and ease of management. These switches are the ideal solution even for the most advanced small and medium organizations looking for the best combination of features, performance, and value.
  • IEEE 802.3at PoE+
    PoE devices encompass VoIP phones, IP Security Cameras, Wireless access points, proximity sensors, door locks and other IoT devices. Wave 2 802.11ac access points and PTZ cameras increasingly require 30W (PoE+).
  • Dedicated SFP fiber uplinks
    Dedicated SFP ports provide fiber uplinks without sacrificing any downlink Gigabit port. 4 SFP ports provide not only redundant uplinks, but can also build dual redundancy by a trunked uplink with link aggregation and failover.
  • Dynamic VLAN assignment
    IP phones and PCs can authenticate on the same port but under different VLAN assignment policies. Users are free to move around and enjoy the same level of network access regardless of their physical location in the network.
  • Static routing
    A simple way to provide segmentation of the network with internal routing through the switch - reserving the router for external traffic routing only, making the entire network more efficient.
  • Comprehensive IPv6 Support for Management, ACL and QoS
    Build current network with future in mind. Ensure investment protection and a smooth migration to IPv6-based network without switch replacement.
  • Build current network with future in mind
    Ensure investment protection and a smooth migration to IPv6-based network without switch replacement. Facilitate fast receiver joins and leaves for multicast streams. Save cost and improve network efficiency by ensuring multicast traffic only reaches designated receivers without the need of an extra Multicast router.
  • Robust security features
    Build a secured, converged network with all types of traffic by preventing external attacks and blocking malware while allowing secure access for authorized users.
NETGEAR Pro GS728TPPv2 - v2 - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L3 - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
380 W
Performance
Bandwidth: 56 Gbps , Forwarding performance (64-byte packet size): 41.67 Mpps
ACL: 100 , ARP entries: 512 , VLANs supported: 256 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP multicast groups: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
DHCP support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, QoS, MLD snooping, DAI, DHCP relay, LACP, DHCP client, MVR, GARP, GVRP, ToS, DSCP support, 2 fans, 1.5MB packet buffer, cable test, ICMP IRDP, IGMP querier, Voice VLAN, Private VLAN, Guest VLAN, DoS protection, WRR, Auto VoIP, MAC lockdown
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25.7 cm x 4.32 cm
4.11 kg
Europe
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
380 W
Performance
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing
Encryption Algorithm
TLS
Authentication Method
RADIUS, TACACS+
1: 700 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, PoE, link/activity
24 x 10/100/1000 Base-T RJ-45 PoE+ , 4 x 1000Base-X SFP , 1 x USB
Internal power supply
Installed Qty
1
Rack Mounting Kit
Included
MTBF
1,071,896 hours
EN 60950, EN55024, CSA 22.2 No. 950, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, FCC CFR47 Part 15 B Class A, IEC 950, ANSI C63.4-2014, EN 55022/CISPR 22 Class A, ICES-003:2016 issue 6 Class A, AS/NZS CISPR22:2009+A1:2010 Class A, AN/NZS 60950.1:2015, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
44 cm
25.7 cm
4.32 cm
4.11 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
