The NETGEAR ProSafe "Intelligent Edge" Gigabit L2+ managed switch GSM5212P consist of 12-port Gigabit with PoE+ connectivity, and 4-port dual-speed SFP with fiber connectivity. Intelligent Edge series deliver a secure and flexible access in campus, commercial and enterprise converged environments: Wireless access points, IP telephony and video-surveillance.
PoE pass-through
In addition to very low acoustics for deployment in open areas, GSM5212P provides PoE pass-through functionality for challenging environments without outlet such as conference rooms or retail sales floors: GSM5212P can be powered by PoE upstream switches and simultaneously power PoE devices downstream. Up to 22 W power can be redistributed locally in pass-through mode. -
Intelligent edge
Combining superior resiliency and advanced security, GSM5212P provides comprehensive Layer 2, Lite Layer 3 and Layer 4 switching, including 16 K MAC table size, 64 routing interfaces and 16 static routes. -
Unified communications - Voice over IP
The NETGEAR ProSafe "Intelligent Edge" simplifies converged data deployments with state-of-the-art capabilities. CoS Layer 2 prioritization and DiffServ Layer 3 and 4 policies allow for 1Kbps ingress and egress TCP/UDP granularity. LLDP-MED (Media Endpoint Discovery) automatically configures IP phones QoS and VLAN settings. -
Unified communications - video streams
IGMP filtering and querier ensure multicast streams are only delivered to interested receivers, preventing flooding even without a dedicated multicast router. When receivers are in different VLANs, Multicast VLAN registration (MVR) uses a dedicated multicast VLAN to forward multicast streams and avoid duplication for clients in different VLANs.
- NETGEAR GSM5212P - switch - 12 ports - Managed - rack-mountable
- Switch - 12 ports - L2+ - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 12 x 10/100/1000 (PoE+) + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching capacity: 24 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
- IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
- 33.1 cm x 20.8 cm x 4.4 cm
- 2.596 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- 8K entries
- Max Units In A Stack
- 8
- Routing Protocol
- Static IP routing
- Authentication Method
- RADIUS, TACACS+
- 12 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE+ , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- 38.5 Watt
- MTBF
- 239,032 hours
- 33.1 cm
- 20.8 cm
- 4.4 cm
- 2.596 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
