iiyama TF3222MC-B1 32" 1920x1080 VGA DVI Touch Large Format Display
Quicklinx: CW6HWS00 Mfr#: TF3222MC-B1
With Full HD resolution and Projective Capacitive 10 point touch technology, the ProLite TF3222MC-B1 delivers seamless and accurate touch response. Featuring AMVA3 LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. The high brightness ensures crispy and clear images, resulting in outstanding information transmission performance, even in bright environments. In addition to the superb image quality, the screen comes with a rugged bezel, making it suitable for demanding environments.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Palm rejection function
    Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode.
  • Open frame
    Open frame monitors are an ideal solution for kiosk integrators and Instore Retail.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite TF3222MC-B1 - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32" - touchscreen
Touch-screen
Panel Type
A-MVA3
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.364 mm
Brightness
500 cd/m²
Contrast Ratio
3000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
8H Hard Coating
Voltage
74.85 cm x 6.2 cm x 45 cm
12.5 kg
DDC-2B, VESA DPMS, cULus, TUV Bauart, CU
Display Type
Diagonal Size
32"
Viewable Size
31.5"
Panel Type
A-MVA3
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Brightness
500 cd/m²
Brightness w/touchscreen
425 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
31.47 - 67.5 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
8H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch
HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
12.5 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB (Type B)
Mechanical
VESA Mounting Interface
200 x 200 mm
1 x VGA cable , 1 x USB cable
Input Voltage
Power Consumption (Typical)
48 Watt
Linux, Microsoft Windows 7 / 8 / 10
