iiyama ProLite TF2738MSC-B1 27" 1920x1080 5ms HDMI DVI DP Monitor
Quicklinx: CW49WS00 Mfr#: TF2738MSC-B1
With Full HD resolution and Projective Capacitive 10-point touch technology, the ProLite TF2738MSC-B1 delivers seamless and accurate touch response. Featuring AMVA+ LED LCD screen technology, it offers exceptional color performance and wide viewing angles. Its rugged bezel with edge-to-edge glass makes it very suitable for applications like table top integration. Equipped with speakers, DVI, HDMI and DisplayPort inputs for multiple connecting possibilities. The ProLite TF2738MSC-B1 is an ideal screen for kiosk integrators and a perfect solution for interactive digital signage, instore retail, gaming and interactive presentations.
  • AMVA+
    AMVA+ Panel technology offers 24-bit True Color performance and amazing viewing angles.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Open frame LFD
    Open frame monitors are an ideal solution for kiosk integrators and instore retail.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Speakers
    This LED monitor is equipped with two high-quality stereo speakers.
iiyama ProLite TF2738MSC-B1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27" - touchscreen
Energy Class
Class A
Energy Consumption per Year
44 kWh
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.31125 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 12 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Screen Coating
6H Hard Coating
Voltage
AC 100 - 240 V (50/60 Hz)
64.85 cm x 5 cm x 38.65 cm
7.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, cULus, TUV Bauart, IPX1, CU
3-year warranty
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.31125 mm
Brightness
300 cd/m²
Brightness w/touchscreen
255 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
6H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese, Chinese
HDCP, Eco-Mode, tempered glass, Advanced Contrast Ratio (ACR), edge-to-edge glass, X-Res Technology, scratch-resistant, Projected Capacitive Touch (PCT) technology, blue light reduction, i-Style Color, Wide Viewing Angle
7.7 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Touchscreen
Movement Detection Technology
Capacitive
DVI-D , HDMI , DisplayPort , Headphones (mini-jack) , USB
Mechanical
VESA Mounting Interface
200 x 100 mm
Water-resistant, dust-resistant, fanless, rugged, portrait / landscape mode
Cable management cover
1 x HDMI cable , 1 x DisplayPort cable , 1 x DisplayPort cable - miniDisplayPort to DisplayPort , 1 x USB cable
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Linux, Apple MacOS X, Android, Microsoft Windows 7 / 8 / 10
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
10 - 80% (non-condensing)
