The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
- Iiyama ProLite TF1734MC-B1X - LED monitor - 17"
- LED-backlit LCD monitor - 17" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Screen Coating
- 7H Hard Coating
- Black
- 36.9 cm x 4.75 cm x 30.7 cm
- 3.6 kg
- VESA DPMS, CB, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- 10-point multi-touch, scratch-resistant
- Black
- 3.6 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , USB
Mechanical
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
- Mounting Kit
- Included
- Power Supply
- External
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.02 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.24 |
C2G 2-Port USB 2.0 Manual Switch | In Stock | £16.25 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £11.34 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £25.75 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £14.89 |
