iiyama ProLite E1980SD-B1 19" 1280x1024 5ms DVI-D VGA Black Monitor with Speakers
Quicklinx: 8TK3WS00 Mfr#: E1980SD-B1
Select:
  • 19"
The 19" ProLite E1980SD is a LED-backlit monitor with 5 ms response time, high contrast and sRGB and gamma correction functions that permit even the finest nuances of color to be set accurately.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
iiyama ProLite E1980SD-B1 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class E
Power Consumption (On mode)
14.5 W
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
41.1 cm x 18.95 cm x 40.2 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, VCCI Class B
Display Type
Energy Class
Class E
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+75 / -85
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
3.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-4/+21
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
Input Voltage
14.5 W
14.5 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
ENERGY STAR Certified
