HPE ProCurve 1500W POE+ ZL
Quicklinx: 82QLWS00 Mfr#: J9306A
HP J9306A ProCurve 1500 W PoE+ ZL Redundant Power Supply For 5400zl, 8200zl Series, 5412zl Switches
Redundant power supply can be used with the HP Procurve power supply shelf (J8714A) to provide additional PoE or PoE+ power to any of the zl switches.
The HP ProCurve switch zl internal power supplies (J8712A, J8713A or J9306A) are redundant power supplies that you can add to any of the HP ProCurve zl switches to provide additional switch reliability.
  • Dimensions: 5.1"(H) x 0.8"(W) x 6.3"(D)
  • Compatibility: ProCurve switches 5400 zl series, 8200 zl series, 5412zl, 8212zl
  • Connects devices: PC
  • Output power: 1.5 kW
  • Input current: 13 A at 110 VAC/10 A at 220 VAC
  • Plug-in module
  • Form factor: Plug-in module, internal
HPE - power supply - 1500 Watt
Power supply
Power Capacity
1500 Watt
HP Switch 5406zl-48G-PoE+; HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2, Switch 8206zl, Switch 8212zl; HPE Aruba 5406, 5406-44G-PoE+/4SFP, 5406-44G-PoE+-2XG v2, 5412-92G-PoE+/4SFP, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2
Power supply
Power Capacity
1500 Watt
HP Switch 5406zl-48G-PoE+ , HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch, Switch 8206zl, Switch 8212zl , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl
