HPE OfficeConnect 1850 24G 2XGT PoE+ 185W Switch
Quicklinx: CRV8WS00 Mfr#: JL172A
Type: 10 Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
£802.27 ex VAT
£962.72 inc VAT
HPE OfficeConnect 1850 Switch Series devices are basic smart-managed, fixed-configuration Gigabit plus 10 Gigabit Ethernet Layer 2 switches designed for small businesses looking for high performance in an easy-to-administer solution.
OfficeConnect 1850 Switches support flexible installation options including mounting on wall, under table, or on a desktop. These Gigabit switches are plug-and-play out of the box, yet network operation can be fine-tuned through features available from a simple web browser-based GUI, if necessary. Customizable features include VLANs, Rapid Spanning Tree, IGMP Snooping, link aggregation trunking and DSCP QoS policies.
All models include the latest energy-saving capabilities, including Energy Efficient Ethernet (EEE) and idle-port power down. All models include variable speed fans operating only at the speed necessary to maintain operating temperature to reduce excess noise and power consumption by the switch.
  • Performance and Reliability
    The HPE OfficeConnect 1850 Switch Series offers choice and flexibility with a complete portfolio of Gigabit and 10 Gigabit basic smart managed Layer 2 switches.The series consists of four Gigabit switches including PoE+ and non-PoE models, each with 10GBASE-T uplinks and one 8-port 10G aggregator switch with eight 10GBASE-T and two dual personality SPF+ ports that delivers 10G connectivity to the edge switches.Spanning Tree Protocol (STP) and Rapid Spanning Tree Protocol (RSTP) provides redundant links while preventing network loops.
  • Easy-to-Use, Simple to Deploy and Manage
    The HPE OfficeConnect 1850 Switch Series features an intuitive Web management interface with an enhanced navigation pane for easy management of devices by non-technical users. It is ideal for organizations that require simplicity.Customizable features include VLANs, Spanning Tree, Link aggregation, and IGMP Snooping. All models include Rapid Spanning Tree Protocol (RSTP) and DSCP Quality of Service (QoS) policies.These switches support flexible installation options, including mounting on walls, under tables or on desk tops.
  • Energy Efficiency and Lower TCO
    The HPE OfficeConnect 1850 Switch Series include the latest energy-savings capabilities, including Energy Efficient Ethernet (IEEE), idle-port power down and PoE Port Scheduler.All switches are covered by a Limited Lifetime Warranty.
  • Quality of Service (QoS)
    The HPE OfficeConnect 1850 Switch Series traffic prioritization provides time sensitive packets (like VoIP and video) with priority over other traffic based on DSCP or IEEE 802.1p classification. Packets are mapped to eight hardware queues for more effective throughput.Broadcast control allows limiting of broadcast traffic rate, to reduce unwanted network broadcast traffic.IEEE 802.11p/Q delivers data to devices based on the priority and type of traffic.
HPE OfficeConnect 1850 24G 2XGT PoE+ 185W - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10Base-T
Power Over Ethernet (PoE)
PoE+
PoE Budget
185 W
Performance
Throughput: 65 Mpps , Switching capacity: 88 Gbps , Latency (100 Mbps): 8.6 µs , Latency (1000Base-T): 3.6 µs , Latency (10 Gbps): 3.6 µs
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Remote Management Protocol
SNMP 1, SNMP 2c, HTTPS
Full duplex capability, Layer 2 switching, auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, half duplex mode, full duplex mode, QoS, DHCP client, 1.5MB packet buffer, NTP
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
44.25 cm x 24.64 cm x 4.4 cm
3.3 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE+
PoE Budget
185 W
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Encryption Algorithm
SSL
1 x ARM Cortex-A9: 400 MHz
RAM
128 MB DDR3 SDRAM
12 x 1000Base-T RJ-45 PoE+ - 185 W , 12 x 1000Base-T RJ-45 , 2 x Gigabit / 10Gbit LAN RJ-45
Internal power supply
222.9 watt
Rack Mounting Kit
Included
MTBF
71.4 years
CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, UL 60950, RoHS, IEC 60950-1, EN 60950-1, WEEE, CSA C22.2 No. 60950-1-07 Second Edition, VCCI Class A, CNS 13438, ICES-003 issue 5 Class A, EN 60825-1:2007, FCC CFR47 Part 15 B Class A, EN 55032:2015
44.25 cm
24.64 cm
4.4 cm
3.3 kg
Limited warranty - advance parts replacement - lifetime - shipment - response time: next business day , Technical support - phone consulting - lifetime - shipment
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CRV8 HPE Foundation Care Next Business Day Exchange Extended Service Agreement 3 Years In Stock £50.81
Ports: 24
Managed: Yes
POE: PoE+
Brand: HPE
Price Range Ex VAT: £750 - £1000
