The HPE OfficeConnect 1920S Switch Series, is designed for small businesses that require enhanced performance to support bandwidth-demanding applications. They are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The switches are advanced smart-managed fixed configuration Gigabit switches that are optimized for small business price/performance. They offer 8-, 24- and 48-port configurations, choice of PoE+ and non-PoE+ models; some include SFP slots for fiber connectivity.
Simplifies Network Deployment and Management for Small Organizations
The HPE OfficeConnect 1920S Switch Series features easy-to-use, out of the box, plug-and-play deployment.The series offers a complete portfolio of choices for increased small business flexibility. It consists of six rack-mountable models including 8G-, 24G- and 48G-port with and without PoE+. The 24G- and 48G-port PoE+ models offer SPF fiber connectivity.These smart-managed switches use an intuitive Web management interface, to simplify deployment and management while offering granular control of key features. -
Keeps Your Business Protected with Enhanced Security
The HPE OfficeConnect 1920S Switch Series supports Energy Efficient Ethernet for lower power consumption and an enhanced feature set for more robust operation.Enhanced security features such as Access Control List, IEEE 802.1x and VLANs guard your network from unwanted or unauthorized access.Management security restricts access to critical configuration commands, offers multiple privilege levels with password protection and supports secure http (https). -
Delivers Better Performance at a Lower Total Cost of Ownership
The HPE OfficeConnect 1920S Switch Series delivers advanced functionality in smart-managed switches, including Layer 3 static routes, SFP ports, rate limiting, link aggregation and IGMP.The switch series includes PoE+ options to power IP devices without the cost of additional cabling.Green features like port shutdown and Energy Efficient Ethernet compliance for greater energy-efficiency.The switch series is covered by the Limited Lifetime Warranty with 24x7 phone support for 90 days and business hours thereafter.
- HPE OfficeConnect 1920S 48G 4SFP PPoE+ 370W - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L3 - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 24 x 10/100/1000 + 4 x 100/1000 SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Latency (100 Mbps): 7 µs , Latency (1 Gbps): 2 µs , Throughput: 77.3 Mpps , Routing/switching capacity: 104 Gbps
- Capacity
- Routing table entries: 32
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- IGMP, static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON, SNMP 3, SNMP 2c, HTTP, HTTPS
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, half duplex mode, full duplex mode, STP support, RSTP support, MSTP support, ACL support, QoS, fanless, DHCP relay, DHCP client, port isolation, CoS, 1.5MB packet buffer, Link Aggregation, NTP, LLDP-MED
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44.25 cm x 32.26 cm x 4.39 cm
- 4.4 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- 16000 entries
- 9216 bytes
- Routing Protocol
- Authentication Method
- RADIUS
- Processor
- 1 x ARM Cortex-A9: 400 MHz
- RAM
- 256 MB SDRAM
- Flash Memory
- 64 MB
- 24 x 1000Base-T RJ-45 PoE+ , 24 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP
- Voltage Required
- MTBF
- 45 years
- 44.25 cm
- 32.26 cm
- 4.39 cm
- 4.4 kg
- Limited warranty - advance parts replacement - lifetime - shipment - response time: next business day , Technical support - phone consulting - lifetime - shipment
- 0 °C
- 40 °C
- 15 - 95% (40 °C)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 15 - 95% (60 °C)
Aruba SFP Transceiver Module 1000Base | In Stock | £122.19 |
