HPE HP 1950 24G 2SFP+ 2XGT 2xDAC Bndl
Quicklinx: BR44WS00 Mfr#: JH376A
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£755.20 ex VAT
£906.24 inc VAT
The HPE 1950 switch series consists of smart web-managed Gigabit Ethernet switches for advanced small business customers needing high-performance connections to servers and network storage. The 1950 switch series has an intuitive web-based interface for simple customization of network operation. It supports truestacking, allowing up to four devices to be logically administered as a single entity, simplifying administration while supporting greater network redundancy.
HPE 1950 24G 2SFP+ 2XGT 2xDAC Bundle - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x Gigabit SFP / 10 Gigabit SFP+ + 2 x 10Gb Ethernet
Performance
Throughput (64-byte packet size): up to 95.2 Mpps , Routing/switching capacity: 128 Gbps
Static routes: 32 , Virtual interfaces (VLANs): 8 , IPv4 routing table entries: 32 , IPv6 routing table entries: 32
MAC Address Table Size
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
IGMP, VRRP, static IPv4 routing, static IPv6 routing, ECMP
Remote Management Protocol
SNMP 1, RMON 2, RMON, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, STP support, ACL support, QoS, STP Root Guard, LACP, DHCP client, packet storm protection, CoS
IEEE 802.3, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
43.6 cm x 16 cm x 4.4 cm
3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
RAM
1 GB (max)
Flash Memory
128 MB
24 x 1000Base-T RJ-45 , 2 x Gigabit / 10Gbit LAN SFP+ , 2 x 10GBase-T RJ-45 , 1 x console RJ-45 management
Internal power supply
2 x 10G SFP+ to SFP+ cable - 1.2 m
MTBF
87.2 years
CISPR 22 Class A, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, ICES-003 Class A, RoHS, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, VCCI Class A, EN 61000-3-2:2000, GB 4943.1
43.6 cm
16 cm
4.4 cm
3 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 24
Managed: Yes
Brand: HPE
Price Range Ex VAT: £750 - £1000
