HPE OfficeConnect 1405 5G v3 Switch
Quicklinx: CLC3WS00 Mfr#: JH407A
1405 series switch is Plug-and-Play unmanaged fixed-port layer 2 switches designed for small offices. The switch is preconfigured for fast, easy installation, with connections using low-cost Ethernet copper cabling. It supports administration-friendly features such as auto-negotiation and automatic cable type detection (MDI/MDIX). It is fan less for quiet and "green" operation, and designed for high reliability, long life, low power consumption, and low total cost of ownership.
  • Traffic prioritization
    Allows real-time traffic classification mapped to multiple hardware queues.
  • Class of Service (CoS)
    Prioritizes traffic by honoring Differentiated Services Code Point (DSCP).
  • Auto-MDIX
    Automatically adjusts for straight-through or crossover cables on all 10/100 and 10/100/1000 ports.
  • Flow control
    Helps ensure reliable communications during full-duplex operation.
  • Comprehensive LED display with per-port indicators
    Provides an at-a-glance view of status, activity, speed, and full-duplex operation.
  • Fanless design
    Enables quiet operation for deployment in open spaces.
HPE OfficeConnect 1405 5G v3 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Switching capacity: 10 Gbps , Throughput: 7.4 Mpps , Latency (100 Mbps): 3 µs , Latency (1000Base-T): 2.6 µs
MAC Address Table Size
2048 entries
Jumbo Frame Support
9216 bytes
1MB packet buffer, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex capability, fanless, DSCP support, Layer 2 switching, QoS, CoS, flow control, Energy Efficient Ethernet
IEEE 802.1p, IEEE 802.3az, IEEE 802.3x, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
11.43 cm x 9.14 cm x 3.56 cm
180 g
3-year warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2048 entries
Jumbo Frame Support
9216 bytes
5 x 1000Base-T RJ-45
Internal power supply
3 watt
UL 60950, IEC 60950-1, EN 60950-1, CAN/CSA C22.2 No. 60950-1-03, EN55022 Class B, ICES-003 Class B, FCC Part 15 Class B, AS/NZS CISPR 22 Class B, Plug and Play, RoHS, WEEE
11.43 cm
9.14 cm
3.56 cm
180 g
Limited warranty - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CLC3 HPE Foundation Care Next Business Day Exchange Extended Service Agreement 3 Years In Stock £14.97
