Honeywell EVO Wireless Battery Siren
Quicklinx: D3WFWS00 Mfr#: SEF8MS
Ideal for larger homes, it provides an unmissable outdoor warning. The 103 decibel siren and flashing LEDs will help deter intruders and alert your neighbours.
  • Sound level 103dBA
  • Operating temperature -25°C to +60°C
  • Eight batteries (AA lithium)
  • 4 year battery life
  • 240 x 330 x 73mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Honeywell evohome SEF8MS - siren - white
Siren
Power Source
Wireless
Siren Sound Level
103 dB
Frequency Band
868 MHz
White
24 cm x 33 cm x 7.3 cm
Siren
Power Source
Wireless
Max Range Open Space
1000 m
Frequency Band
868 MHz
Siren Sound Level
103 dB
AA type
Battery Included
Required Qty
8
Lithium
White
IP44
24 cm
33 cm
7.3 cm
1 kg
-25 °C
60 °C
