Brand
Ring Indoor Camera (2nd gen) - White
Quicklinx: H8ZGWS00 Mfr#: B0B6GKH3C2
Type: Indoor Camera
Compatible With: Alexa
More than 50 In Stock
£41.66 ex VAT
£49.99 inc VAT
Get the whole picture about what's happening inside your home, or keep the picture private by using the manual, removable Privacy Cover to turn off audio and video with a simple swivel. Versatile protection and personalised peace of mind - that’s Indoor Camera (2nd Gen). The ideal way to check in on your home from wherever you are, Indoor Camera (2nd Gen) is a versatile plug-in Security Camera, designed to go almost anywhere indoors.
Easy to install and with a compact design, Indoor Camera (2nd Gen) simply plugs in to a standard electrical socket, so you can add protection wherever you need it inside your home.
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H8ZG 047636
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £32.31
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Indoor Camera
Brand: Ring
Stock Status: Used Stock
