Ezviz Full HD Outdoor Floodlight Security Camera - White
Quicklinx: H0WPWS00 Mfr#: CS-LC1C-A0-1F2WPFRL (white)
Colours:
The EZVIZ LC1C is a security camera and outdoor floodlight in one amazing package, meeting your need for both security and nighttime illumination in the yard, driveway, and more. More than just blasting a combined 2000 lumens of brightness, the LC1C camera monitors your surroundings with active defense and real-time motion notifications.
  • Images are brilliant, day and night
    Thanks to a starlight standard sensor, not just daytime videos are stunning, nighttime images are crisp-clear and bright despite the environmental darkness. Now you can see everything up to 25 meters (82 ft.) away clearly with the camera's advanced night vision.
  • Thoughtful way to illuminate your yard
    The LC1C is a perfect replacement of yard lights. Designed with flexibility in mind, the LC1C can be rotated to face any direction you need. To use it as a conventional yard light, you may toggle the floodlights on manually and adjust brightness all by using the EZVIZ app.
  • Smart lighting
    Outfitted with a 270-degree PIR sensor, the LC1C's floodlights automatically light up upon detection of people or animals in the darkness. You can even configure which zones you'd like to enable PIR motion-activated lighting!
  • Motion alerts are more accurate than ever
    The LC1C adopts a double-trigger mechanism to boost alert accuracy. By combining the traditional motion detection analytics with a PIR sensor, the LC1C makes sure you only receive attention-worthy notifications.
  • Two-way talk
    The LC1C makes two-way communication even easier with its powerful microphone and speaker. Using the EZVIZ app, both sides can hear each other loud and clear.
  • Enhanced connectivity
    The onboard Wi-Fi module of the LC1C leverages a PA (Power Amplifier) to greatly improve its signal strength and anti-interference capability. In addition, two powerful built-in antennas make sure the LC1C stays online better than ever.
EZVIZ LC1C - network surveillance camera
Network surveillance camera - fixed - outdoor
Audio
Yes: built-in speaker, two-way audio capability, built-in omni-directional microphone
18.5 cm x 26.8 cm x 18.6 cm
1.469 kg
White
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
25 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Backlight Compensation (BLC), Wide Dynamic Range (WDR), PIR-based motion detector, Smart Light Control, reset button, Smartphone Monitoring, 2 LED lamps, cloud recording, Starlight Technology, 3D digital noise reduction (DNR), instant notification, built-in siren (100 dB)
Environmental Parameters (operating)
-30 °C - 50 °C; 0 - 95% relative humidity
Audio Support
Wireless
18.5 cm
26.8 cm
18.6 cm
1.469 kg
Camera
Colour - Day&Night - fixed - outdoor
Digital Video Format
H.264, H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
25 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Lens Construction
Horizontal Field of View (degree)
103
Vertical Field of View (degree)
57
Diagonal Field of View (degree)
121
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Screws
FCC Part 15, IP65, Directive 2006/66/EC, RoHS 2011/65/EU, WEEE 2012/19/EU, EMC 2014/30/EU, Directive 2013/56/EU, RED 2014/53/EU
White
AC 120/230 V 35 Watt
Shipping Width
23.5 cm
Shipping Depth
23.5 cm
Shipping Height
25 cm
-30 °C
50 °C
Relative Humidity (operating)
0 - 95%
