Our most powerful floodlight camera
The first 100% wire-free floodlight camera illuminates the most vulnerable parts of your property. A motion-activated light more powerful than a car headlight deters intruders before they even get close to your property. While 2K video captures all the important details for the best possible protection.
Wire-Free Security Installed in Minutes.
Easily mounts in multiple locations for protection from every angle.
Never be left in the dark
Light up your property with 2000-3000 lumens.
Color Night Vision
See video in full color or traditional black and white.
2K HDR
Zoom in on objects and capture clearer details and colors.
160° Viewing Angle
Keep an eye on what matters with a wide 160° diagonal field of view.
2-Way Audio
Hear and speak to visitors clearly with superior audio quality.
Built-in Smart Siren
Trigger your siren automatically, or manually from the Arlo app.
Weather-resistant design
Built to withstand heat, cold, rain or sun.
Custom control
Easily adjust brightness, video, and audio settings to your preference.
Rechargeable battery
Go wire-free with a convenient and long-lasting battery.
Multiple power options
Keep your floodlight camera charged all day with an optional Solar Panel or Outdoor Charging Cable (sold separately).
3-month Arlo Smart trial included
Personalized notifications keep you informed of events that matter so you can take quick action—from phoning a friend to sound an alarm, or calling emergency services.
What's included:
(1) Arlo Pro 3 Floodlight Camera
(1) XL Rechargeable Battery
(1) Power Adapter
(1) Micro-USB Cable
(1) Wall Plate and Screw Kit
(1) Quick Start Guide
(1) Video Monitoring Decal
Powerful brightness
3000 lumens and 2K color night vision. -
Wire-free
Connect directly to Wi-Fi, no base station required. -
2K video with HDR
Zoom in up to 12x with a 160-degree view. -
React and respond
Two-way audio and siren to deter intruders. -
Simple setup
The Pro 3 Floodlight Camera can be connected to your home Wi-Fi network. The included wall plate and screw kit let you put the Pro 3 Floodlight Camera up in a wide range of place outdoors.
- Arlo Pro 3 Floodlight Camera - network surveillance camera
- Network surveillance camera - fixed - indoor, outdoor - weatherproof
- Audio
- Yes: two-way audio capability, built-in microphone
- Camera Mount Type
- Wall mount
- 21.852 cm x 19.05 cm x 7.793 cm
- 650 g
- Black
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Video Modes
- 2K, 1080p, 720p
- Optical Sensor Type
- 1/3" - 4 MP
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - micro-USB cable - external
- High Dynamic Range (HDR), built-in spotlight, built-in siren, Colour Night Vision
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Audio Support
- Camera Mount Type
- Wall mount
- Wireless
- 21.852 cm
- 19.05 cm
- 7.793 cm
- 650 g
- Localisation
- Europe
Camera
- Colour - Day&Night - fixed - indoor, outdoor - weatherproof
- Digital Video Format
- H.265, H.264
- Max Digital Video Resolution
- 2560 x 1440
- Video Modes
- 2K, 1080p, 720p
- Digital Zoom
- 12
Image Sensor
- 4 MP 1/3"
Lens Construction
- Horizontal Field of View (degree)
- 160
- Network Interface
- Included Accessories
- Wall mount kit, screw kit, video monitoring decal, rechargeable battery
- Cables Included
- 1 x micro-USB cable - external
- Black
- Power Device
- Power adapter - external AC 100 - 240 V
- Battery
- 1
- Limited warranty - 1 year
- Shipping Width
- 24.5 cm
- Shipping Depth
- 19.8 cm
- Shipping Height
- 13.4 cm
- Shipping Weight
- 1.362 kg
- -20 °C
- 45 °C
